| View previous topic :: View next topic |
| Author |
Message |
americansoldier
Joined: 15 Aug 2008 Posts: 605 Location: Lawrence ( stationed in GA) currently in Iraq
Posted: Sun Sep 27, 2009 6:05 pm Post subject: is this a good trade for nitrous?? |
ok on clubgp i posted a sony touchscreen camcorder that i paid 950 bucks for sale for 300 bucks or trade for mods..this guy on on there offered me this http://www.clubgp.com/newforum/tm.asp?m=4909753&appid=&p=&mpage=1&key=&language=&tmode=&smode=&s=#4909753 but i dont know JACK about nitrous so is this a good deal or what? and what does he mean "driller" do i NEED a purge kit, bottle heater or anything else he aint including? thanks guys! _________________ 2003 GTP - 1.95 YT Roller Rockers, LS6 Springs, Pushrods, Powerlog, 3" Downpipe, K&N Intake, 3.5, Overkill Pcm, Magnaflow Cat Back, ZZP STB, L.E.D Tails, Poly Motor Mounts
SSAC Headers +N20 in garage
| Back to top |
deekster_caddy
Joined: 20 May 2007 Posts: 2524 Location: Reading, MA
Posted: Sun Sep 27, 2009 6:26 pm Post subject: |
If you don't know N2O, the L67 is not exactly a good place to do your learning. The L67 is on the edge of popping pistons already once you have some mods done... keeping it on that edge and adding N2O is no easy task. That and I really don't like the Zex kit.
But if you want to play, it's not an unreasonable offer if the kit is still complete. _________________ '98 Buick Riviera; Gen V 3.2 pulley, N*, VS Cam, 180 stat, Custom PCM (Powrtuner), headers & HF cat , 42.5 lb inj.
| Back to top |
3800tom
Posted: Sun Sep 27, 2009 6:52 pm Post subject: |
| i believe he meant to say Drilled not driller |
| Back to top |
americansoldier
Posted: Sun Sep 27, 2009 8:46 pm Post subject: |
hmm..i may just take it then try to trade the zex kit for some rockers..idk i gotta do my research either way first _________________ 2003 GTP - 1.95 YT Roller Rockers, LS6 Springs, Pushrods, Powerlog, 3" Downpipe, K&N Intake, 3.5, Overkill Pcm, Magnaflow Cat Back, ZZP STB, L.E.D Tails, Poly Motor Mounts
| Back to top |
reveregtp
Posted: Sun Sep 27, 2009 8:48 pm Post subject: |
i traded my zex kit with warmer purge kit and tie down for a powertuner, so its going for about $300 these days... the rockers u can find for $200-250 _________________
| Back to top |
murphinator
Joined: 02 Nov 2007 Posts: 1604 Location: Old Orchard Beach , Maine
Posted: Sun Sep 27, 2009 10:14 pm Post subject: |
my concern with that kit (assuming its a dry kit) is spraying via tb spacer
when you spray via tb spacer you are counting on narrowband 02's to tell the pcm to enrich the fuel mixture as far as I know - cant think of any other sensor that will see the change ??
I run a dry kit but spray pre maf & pre iat so the iat sees the incoming charge is well below zero and knows there is a large volume of intake charge passing by the maf , from there as long as you have headroom on your fuel supply its somewhat safe...
you could always run that kit along with a boost referenced meth kit and a wideband and get it safe _________________ 2002GS 204 K mi.
PB's 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap
98GS 98K 14.4 @96 with fwi only , 98 GS 137k
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94 60 FOOT 1.906
| reveregtp wrote: | | hmm perhaps asscrack sunday morning |
| Back to top |
americansoldier
Posted: Mon Sep 28, 2009 8:28 pm Post subject: |
getting the kit sent to me tom..wicked stoked..still need purge kit/bottle blanket, gauges, colder plugs and a hella tune before this gets hooked up..prob aint happening til after iraq where ill have headers/rockers and more money to get it right
nitrous=  _________________ 2003 GTP - 1.95 YT Roller Rockers, LS6 Springs, Pushrods, Powerlog, 3" Downpipe, K&N Intake, 3.5, Overkill Pcm, Magnaflow Cat Back, ZZP STB, L.E.D Tails, Poly Motor Mounts
| Back to top |
americansoldier
Posted: Thu Oct 01, 2009 8:53 pm Post subject: |
new mod here _________________ 2003 GTP - 1.95 YT Roller Rockers, LS6 Springs, Pushrods, Powerlog, 3" Downpipe, K&N Intake, 3.5, Overkill Pcm, Magnaflow Cat Back, ZZP STB, L.E.D Tails, Poly Motor Mounts
| Back to top |
BigBlock73
| Back to top |
deekster_caddy
Posted: Wed Oct 14, 2009 2:02 pm Post subject: |
hoooollyyyy shit!!! wow! Glad that wasn't my car!!! _________________ '98 Buick Riviera; Gen V 3.2 pulley, N*, VS Cam, 180 stat, Custom PCM (Powrtuner), headers & HF cat , 42.5 lb inj.
| Back to top |
BillBoost37
Posted: Wed Oct 14, 2009 2:12 pm Post subject: |
Was probably Adam's attempt at nitrous..lol _________________
| Swiggles wrote: | | pics slow down the build process .... |
97 B'ville SSEi Gen V, S1X, 1.8RR's, N*, 3.29's w/LSD, .592" of lift happiness |
| Back to top |
BigBlock73
Posted: Wed Oct 14, 2009 2:18 pm Post subject: |
har har. I only ran nitrous once in my car. Man was it fucking insane. I hit it on a back road in my challenger at about 50mph. I topped out my car at 120 and ran out of road before i could blink. _________________ Billboostified 98 GS stock and stayin that way.
| Back to top |
Supercharged03GTP
Posted: Wed Oct 14, 2009 11:43 pm Post subject: |
Daaaaaaaaaaaaaaaaaaaaaaaaaamn! That is insane. _________________
2003 Pontiac Grand Prix GTP Limited Edition (Stock) for now |
| Back to top |
