New England Pontiac Enthusiast Club The Place for Pontiac Fans in New England to Hang Out
| View previous topic :: View next topic |
| Author |
Message |
Speedy0009
Posted: Sun Jul 22, 2007 12:21 pm Post subject: Went Drag Racing at NED July 21st 2007 |
Here are my results!
Well, I went up early in the morning before the gate opened. Previous to today my PB was 12.52 @ 114mph with a 1.86 short time back on June 30th.
My new times and PB's are as follows in the pictures of the time slips. The changes I made from June include a used Spec 3 clutch (15K miles plus from my Trans Am) and new slave cylinder, new Billet Pro shifter (see my other thread), new longer ARP wheel studs for strength and safety and I changed the Procharger oil.. LoL
I am car #700...
First and Second passes:
Third and Fourth Passes, notice my second pass and 3rd pass are six minutes apart:
Fifth and Sixth passes:
So on my 5th run of the day I made two new Personal Bests 1.64 short time and 12.095 E.T! My MPH is sucking bad at 114 and I really need to figure out why!! I should be trapping over 120 every time. What gives? Anyhow, my PB was against a C5 ZO6, Blue with the silver stripes, I believe it to be a H/C car that my Tuner recently tuned/dynoed.. I saw it at the shop on the rollers.
Without a doubt, a little more seat time, some cooler air and I'll be consistant 11's! Oh, by the way I think the scale is inaccurate at the track because this time my race weight was 3826.. last time it was 3926 and the car should weigh in at over 4050lbs. I'll will try to get it weighed this week, I just have to bolt the slicks back on to get my "race weight". And with that I mean EVERYTHING is in the car, even a 1/4 quart of transmission fluid (slid under the seat apparently from the clutch install two weeks ago), one quart of motor oil, spare tire, tools, amongst other things!! Ha Ha Ha :eek2: _________________
2004 IBM GTO, M6, blue interior, SAP, Slowhawk 2 Bar SD Tuned, D-1SC ProCharger 4.00" pulley, Alkycontrol methanol injection, Comp 918 valve springs, Mototron 60's, 3.91s, Harrop cover, X-member bushings, Kenne Bell BAP, SLP Sway bar and end link bushings, BMR Drag Bags, B&M Ripper, Kooks 1.75 LTs w/ coated catted mid-pipes, SLP line Lock, DynoJet WideBand ~~ New #'s 531rwhp/440rwtq... and more to come! |
| Back to top |
John Site Admin
Joined: 14 May 2007 Posts: 754 Location: New Durham, NH
Posted: Sun Jul 22, 2007 12:51 pm Post subject: |
wow
congrats on the new PB man  _________________ 1999 Grand Prix GTP
1990 Grand Prix Turbo
GTP: L32 block w/ Gen 3 Blower, S1X Cam, Intercooled, 2.9" pulley, Wizair CAI, Custom-Tuned PCM, TOG headers/RT DP, 42.5# injectors, Poly Motor Mounts, AutoLite 104's, and 180 TStat
'04 PB: 14.212@97.65MPH; '05 PB: 14.024@98.59MPH w/ 2.076 60'; 06 PB: 13.979@101.36MPH w/ 2.35ish 60'; 07 PB: 13.517@102.04MPH w/ 2.071 60' (Not Cammed!); Latest Dyno: 269WHP/357WTQ
*Surgery Complete (for the most part)*
14.146 @ 102.15 after surgery...HAHA (2.375 60')
TGP: K&N on Turbo
15.911 @ 86.52mph 172whp |
| Back to top |
crab daddy
Joined: 16 May 2007 Posts: 1952 Location: Attleboro, MA
Posted: Sun Jul 22, 2007 1:47 pm Post subject: |
very nice, congrats...
I was dieing to race yesterday too. Its all I could think about all day. I was watching my nephew though and had to bring him to cub scouts. _________________ 12.466 @ 114.15 INTENSE S1X/ZZP IC/TOG Headers
86 Fiero GT / 99 Grand Prix GTP / 02 Lincoln LS / 06 Nissan Titan 4x4 |
| Back to top |
BigBlock73
Posted: Sun Jul 22, 2007 1:58 pm Post subject: |
your trap speed and that 12.0 run aren't far off from each other. Maybe some faster shifting will do the trick but i think on that 5th pass the numbers all match up pretty well.
I can't see where your going to pull out another 5+ mph. _________________ 89 Mirage 1.6 liters of fury!!!
Replacing displacement
| Back to top |
Speedy0009
Posted: Sun Jul 22, 2007 4:18 pm Post subject: |
I should be trapping 120-127mph easily on 530rwhp and 440rwtq. Something's just not adding up. I wonder if now the stock cat-back is really just choking the hell out of the car?? _________________
| Back to top |
the driver Official Post Whore of 'em All
Posted: Mon Jul 23, 2007 12:57 am Post subject: |
The cat-back is a definite possibility. If it's going to hurt performance, it would certainly be the top end.
Congrats on the new PBs!!! _________________ Magnaflow = (not so) Fucking loud (now that it's mounted correctly) |
| Back to top |
Speedy0009
Posted: Mon Jul 23, 2007 1:44 am Post subject: |
Thanks..
Yup, another possibility that was brought to mind as well was "am I getting enough air into the blower?". I have the air filter in my inner fender well, it might not be getting enough air from under the car so I might look into a scoop to force the air from under the car at speed to the air filter.. I guess somewhat like the mustangs use or have used in the past! _________________
| Back to top |
gtped
Posted: Mon Jul 23, 2007 9:15 am Post subject: |
Congrats nice times _________________
2000 GTP 201k (SOLD)
2004 Accord LX (wife's)
2004 Seabring Conv.(SOLD)
2004 LESABRE
Ed
www.cardomain.com/ride/847103 |
| Back to top |
sleeperZ96BT
Posted: Mon Jul 23, 2007 9:50 am Post subject: |
Sweet times man.....you'll get your 11's. You could add a cutout pre/post cat and shave off the exhaust going through the stock cat back and see how that goes. Or like you mentioned you can make sure that guy is getting enough air into the charger and revise the intake scheme. ZZP found on their cars (take this at face value) that a FWI could only get the 3800 SC so fast before the intake needed to be moved to a CAI when you were DEEP into the 11's.
Are you RIPPING shifts or just kind of shifting it through the gears? I remember whenever I raced my 96Z I always just shifted it 'normal' and never tore through the gears like I could have. I shifted quicker than stock but never wanted to risk missing a gear and screwing anything up since I liked to drive it so much, so I always made sure the clutch was engaged  _________________ 2000 Monte SS - Almost gone to its new home
2002 40th GTP
1996 Z28 M6 |
| Back to top |
Speedy0009
Posted: Mon Jul 23, 2007 11:36 am Post subject: |
I was ripping the gears hard Brian. I acutally just installed a brand new shifter that I was "breaking in" and well I pulled the knob up off the shaft breaking the seal of the adhesive. I don't worry about missing gears I worry about back shifting (3-2 instead of 3-4) but to prevent that I backhand the shifter these days and it works like a charm! My 1/8th kinda sucks so maybe it's my shifting or something. Waiting on videos that I should be posting tonight.
Check out the shifter here...
http://www.nepontiac.org/forum/viewtopic.php?p=2408#2408 _________________
| Back to top |
Speedy0009
Posted: Wed Jul 25, 2007 4:48 am Post subject: Launch & Burnout pics: |
 _________________
| Back to top |
BigBlock73
| Back to top |
Speedy0009
Posted: Fri Jul 27, 2007 7:22 pm Post subject: |
Not even close... He has a built 347 and an F-1C blower (much larger than the D-1SC I use) as well he doesn't even have to shift the car it's a 4l65e automatic!! LoL not to mention he's probably got 800lbs less race weight than I do.. _________________
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
