New England Pontiac Enthusiast Club Forum Index New England Pontiac Enthusiast Club
The Place for Pontiac Fans in New England to Hang Out
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   ChatroomChatroom  RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
HP TUNER HELP
Goto page 1, 2  Next
Post new topic   Reply to topic    New England Pontiac Enthusiast Club Forum Index -> Grand Prix
View previous topic :: View next topic
Author Message
Sttaaapppeeennn
PostPosted: Thu Jul 29, 2010 10:32 pm    Post subject: HP TUNER HELP Reply with quote
So i got HP tuners now and im trying to figure out why i cant Read Pcm....Anyone know where theres a tutorial where i can learn about this shit?.....Says i have no open COM Ports available
_________________
2000 Grand Prix GTP -- TEP TRANS , TURBOCHARGED. T67 /1.9 Mod Rockers/CC Valve Springs 105's/Plog/48lb Injectors / Borla Exhaust/ ZZP PCM / KYB Struts/K&N Intake/Autolite 104/ SD Appearance Package / Tuned by Deekster Derek and ZZP ------------------PB - 13.7 at 102.4 MPH <<< soon to be broken!!!
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
BillBoost37
PostPosted: Fri Jul 30, 2010 6:43 am    Post subject: Reply with quote
that would be a setup error, not a reading error.
Did you setup the software and does it see the HPT cable? No com ports would point me to thinking that its not seeing it or you have a pc issue.
_________________
Swiggles wrote:
pics slow down the build process ....
97 B'ville SSEi Gen V, S1X, 1.8RR's, N*, 3.29's w/LSD, .592" of lift happiness
Back to top
murphinator
PostPosted: Fri Jul 30, 2010 6:45 am    Post subject: Reply with quote
no open com ports huh. if you ask that on hpt they would tell you to search which I am sure would give you the answer.
I know I have seen that one posted before , are you trying to use an aeroforce at the same timeorhave anything else plugged in your usb's ? I am thinking its along those lines
_________________
2002GS 204 K mi.
PB's 1/4 mi 13.165 108.09 trap ,1/8 mi 8.562 , 84.87 trap
98GS 98K 14.4 @96 with fwi only , 98 GS 137k
GTP ON SPRAY 12.209 @117.75 1/8 MI 7.73 @94 60 FOOT 1.906
reveregtp wrote:
hmm perhaps asscrack sunday morning
Back to top
BillBoost37
PostPosted: Fri Jul 30, 2010 6:47 am    Post subject: Reply with quote
Oh..and you need to join the forum and read until your eyes bleed everyday.
http://www.hptuners.com/forum/forumdisplay.php?f=35
There's a how to or discussion for nearly everything out there. Start doing the required homework. When you read and read and read and then you think "holy shit, that X makes sense" that's the beginning of understanding what is going on. Another year after that revelation you'll be much closer to knowing how it is all intertwined.
_________________
Back to top
murphinator
PostPosted: Fri Jul 30, 2010 6:55 am    Post subject: Reply with quote
a quick search on hpt forum showed the com ports error when trying to have both the scanner and editor open at the same time or when the drivers werent installed properly - that is usually someone with win 7 64 bit that hasnt used the 64 bit specific driver install tutorial from the stickys - should be in the getting started forum stickys
_________________
2002GS 204 K mi.
Back to top
Sttaaapppeeennn
PostPosted: Fri Jul 30, 2010 7:27 am    Post subject: Reply with quote
i already joined HP tuners, i joined that shit before i even owned HP Tuners Smile ......I tried researching the Com ports on HP tuners but i couldnt find anything. Ill have to meet up with someone who knows what there doing and show me the basics.
_________________
Back to top
BillBoost37
PostPosted: Fri Jul 30, 2010 8:07 am    Post subject: Reply with quote
C'mon down.
_________________
Back to top
j6sullivan
PostPosted: Fri Jul 30, 2010 10:33 am    Post subject: Reply with quote
I'm coming down Monday bill lol this is a heads up
_________________
14.0 @98.2 mph Magnaflow Exhaust, TOG Headers, TOG Downpipe w/u-bend Dlt, SLP cai, DHP pcm, 3.4, Autolite 104's, KYB struts, SD Appearance Package
Back to top
Sttaaapppeeennn
PostPosted: Fri Jul 30, 2010 8:47 pm    Post subject: Reply with quote
i would like to come down too but ill be working
_________________
Back to top
Sttaaapppeeennn
PostPosted: Sat Jul 31, 2010 12:14 pm    Post subject: Reply with quote
ok i figured it out.....My drivers werent installed correctly because i have stupid windows vista. They say sometimes when you load the drivers they dont work the first time so you have to uninstall them and then reinstall. It was a pain in the ass process.
_________________
Back to top
ChrisGT
PostPosted: Sun Aug 01, 2010 2:14 pm    Post subject: Reply with quote
Lmao you would whine about re installing drivers.
_________________
01 GT In Progress: Matt's NewTT cam | PT-67 | 18-23psi | Couple stock tranys.
Back to top
View user's profile Send private message Visit poster's website AIM Address
Sttaaapppeeennn
PostPosted: Sun Aug 01, 2010 3:55 pm    Post subject: Reply with quote
yeahh....now my problem is my Vin Number is Different. I have a new PCM that doesnt have my correct Vin Number. When i click change vin number, it says i need a license before i can change the vin. When i try to get a license it says i cant because i dont have matching Vins. Its fucked LOL
_________________
Back to top
BillBoost37
PostPosted: Mon Aug 02, 2010 6:28 am    Post subject: Reply with quote
It's not fucked. It's inconvenient. HPT matches vin to OSID. Meaning they validate that the software in the pcm will work with the hardware it's loaded on.
Have someone with DHP fix your vin (if the pcm is unlocked.). Then HPT will work fine.
_________________
Back to top
JFDugal
PostPosted: Mon Aug 02, 2010 2:44 pm    Post subject: Reply with quote
There used to be a stand alone vin changer floating around on clubgp. Try searching the PCM sections there. I might have a copy of it somewhere. If I find it I'll post it up.
Back to top
Sttaaapppeeennn
PostPosted: Tue Aug 03, 2010 12:05 am    Post subject: Reply with quote
yeah so thats what i need to do for now. I need to find someone who can change my vin. Then i can probably go back to my tuner.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    New England Pontiac Enthusiast Club Forum Index -> Grand Prix All times are GMT - 4 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Designed by Gamerhaven | Updated & Maintained by Thatbitextra
